Кабель коаксиальный CommScope AVA5-50A (7/8 '')
код товара: 380556
Бренд: CommScope
Описание кабеля CommScope AVA5-50A (7/8 '')
AVA5-50, HELIAX® Andrew Virtual Air ™ коаксиальный кабель, гофрированная медь, 7/8, черная оболочка
Product Classification
  • Brand HELIAX®
  • Product Series AVA5-50
  • Product Type Coaxial wireless cable
Standards And Qualifications
  • EN50575 CPR Cable EuroClass Fca
Construction Materials
  • Jacket Material PE
  • Outer Conductor Material Corrugated copper
  • Dielectric Material Foam PE
  • Flexibility Standard
  • Inner Conductor Material Copper tube
  • Jacket Color Black
Dimensions
  • Nominal Size 7/8 in
  • Cable Weight 0.30 lb/ft | 0.45 kg/m
  • Diameter Over Dielectric 24.130 mm | 0.950 in
  • Diameter Over Jacket 27.991 mm | 1.102 in
  • Inner Conductor OD 9.4488 mm | 0.3720 in
  • Outer Conductor OD 25.400 mm | 1.000 in
Electrical Specifications
  • Cable Impedance 50 ohm ±1 ohm
  • Capacitance 22.0 pF/ft | 73.0 pF/m
  • dc Resistance, Inner Conductor 0.410 ohms/kft | 1.435 ohms/km
  • dc Resistance, Outer Conductor 0.340 ohms/kft | 1.116 ohms/km
  • dc Test Voltage 6000 V
  • Inductance 0.184 µH/m | 0.056 µH/ft
  • Insulation Resistance 100000 Mohms•km
  • Jacket Spark Test Voltage (rms) 8000 V
  • Operating Frequency Band 1 – 5000 MHz
  • Peak Power 91.0 kW
  • Velocity 91%
Environmental Specifications
  • Installation Temperature -40 °C to +60 °C (-40 °F to +140 °F)
  • Operating Temperature -55 °C to +85 °C (-67 °F to +185 °F)
  • Storage Temperature -70 °C to +85 °C (-94 °F to +185 °F)
General Specifications
  • Ordering Note CommScope® standard product (Global)
  • Specification Sheet Revision Level B
Mechanical Specifications
  • Bending Moment 19.0 N-m | 14.0 ft lb
  • Flat Plate Crush Strength 75.0 lb/in
  • Minimum Bend Radius, Multiple Bends 254.00 mm | 10.00 in
  • Minimum Bend Radius, Single Bend 127.00 mm | 5.00 in
  • Number of Bends, minimum 15
  • Number of Bends, typical 30
  • Tensile Strength 159 kg | 350 lb
Note
  • Performance Note Values typical, unless otherwise stated
Standard Conditions
  • Attenuation, Ambient Temperature 20 °C | 68 °F
  • Average Power, Ambient Temperature 40 °C | 104 °F
  • Average Power, Inner Conductor Temperature 100 °C | 212 °F
