Бренд: Barcom
Input: 13 SAT + 1 Terr.
Output: 32 Receiver + 13 Sat + 1 Terr
Frequency Range
LNB - Inputs: 950-2200MHz
Terr. Input: 47-862 MHz
Outputs: 47-2200 MHz
Control: Diseqc Commands or 13V / 18V + O/22 kHz
Intertion Loss(Receiver)
950 - 2200 MHz: 1 ….. 6dB
47 - 862 MHz: 3 ….. 8dB
Sat Inputs Isolation
Between V/H Polarisations: > 25 dB
Between Low and High Bands: > 25 dB
Between Sat System A and B: > 30 Db
Maximum İnput Level
Sat.: 90 dB μV
Terr.: 85 dB μV
Maximum Output Level
sat.: 90 dB μV
Terr: 90 dB μV
Product Dimension: 34cm(L) x 16.5cm(W) x 5cm(H)
Gift Box Dimension: 44cm(L) x 19cm(W) x 6cm(H)
Net Weight: 1968gr
Gross Weight: 2365gr
Temperature Range: 10 °C- +60 °C
