Бренд: WISI
Опис плати WISI GT42W
Плата серії WISI Tangram для встановлення 4-х CAM-модулів, дескремблювання цифрових сервісів.
Streaming-In-/Output
IP-Inputs: 32 or 64 or 128 pcs. (128 with GTSTRX Software option)
IP-Outputs: 64 or 128 pcs. (128 with GTSTRX Software option)
IP-Compliance: ISO/IEC 13818
IP-Input bitrate: Max. 110 Mbit/s per IPTS, Max. 400 Mbit/s total
IP-Output bitrate: Max. 100 Mbps per IPTS, Max. 400 Mbps total
IP-Input protocol: UDP/RTP/RTP+FEC Unicast and Multicast, IGMP v2 and v3
IP-Output protocol: UDP/RTP/RTP+FEC Unicast and Multicast, IGMP v2 and v3
IP-TS-Input format: SPTS CBR/VBR, MPTS CBR
IP-TS-Output format: SPTS CBR/VBR, MPTS CBR
IP-FEC inputs: 32 or 128 pcs. (with GTFEC Software option)
IP-FEC Outputs: 32 pcs. (with GTFEC Software option)
IP-FEC compliance: SMPTE 2022-1, SMPTE 2022-2
IP-Packet format: MPEG over UDP/IP and RTP/IP
IP-Packet size: 188 Byte
IP-PCR restamping: Yes
IP-Dejittering: Yes, per default 100ms, individual adjustable
Processing
Service remultiplexing: Yes, with GTMUX Software option
Service remultiplexing before decryption: Yes, with GTMUX Software option
PID filtering and remapping: Yes
PCR correction and de-jitter: Yes
Advanced PSI/SI regeneration :Yes
Encryption: -
Encryption throughput: -
Decryption: Yes, with CAM and Smart Card
Decryption throughput: Depending of the CAM, max. 850 Mbps total
Compliance: ETSI EN 300 468
Processing bitrate: Max. 1200 Mbps total
Number of PIDs: Max. 4000 PIDs total
Connectors
RJ45: 1 pcs.
Common Interface: 4 pcs.
General data
Power consumption max.: max. <10 W
Operating temperature range: -5°C...+45°C, 23°F...113°F, (ETSI EN 300 019-1-3 Class 3.1)
Max. humidty (non condensing): 95 %
Electro Magnetic Compatibility (EMC): EN 50083-2
Safety compliance: UL/CSA/CAN 60950-1
