Camera
Sensor: 1/2.5', 8.0 megapixel, progressive scan, CMOS
Lens: 2.8mm @F2.0
Angle of view (H): 118.1°
Angle of view (V): 64.0°
Angle of view (O): 153.5°
DORI Distance: Detect (m) - 50.4, Observe (m) - 20.2, Recognize (m) - 10.1, Identify (m) - 5
Adjustment Range: Pan: 0°~ 360° Tilt: 0° ~ 90° Rotation: 0° ~ 360°
Shutter: Auto/Manual, 1 ~ 1/100000s
Minimum Illumination: Colour: 0.001Lux (F2.0, AGC ON), 0Lux with IR
Day/Night: IR-cut filter with auto switch (ICR)
Digital noise reduction: 2D/3D DNR
S/N: >52dB
IR Range: Up to 30m (98ft) IR range
Defog: Digital Defog
WDR: 120dB
Video
Video Compression: Ultra 265, H.264, MJPEG
H.264 code profile: Baseline profile, Main Profile, High Profile
Frame Rate: Main Stream: 8MP (3840*2160), Max 20fps; Sub Stream: 1080P (1920*1080), Max 30fps; Third Stream: D1 (720*576), Max 30fps
HLC: Supported
BLC: Supported
9:16 Corridor Mode: Supported
OSD: Up to 8 OSDs
Privacy Mask: Up to 8 areas
ROI: Up to 8 areas
Motion Detection: Up to 4 areas
Smart
Behavior Detection: Intrusion, cross line, motion detection
Intrusion: Enter and loiter in a pre-defined virtual region
cross line: Cross a pre-defined virtual line
motion detection: Moving within a pre-defined virtual region
Recognition: Face detection
Intelligent Identification: Defocus, Scene Change
Statistical Analysis: People counting
General Function: Watermark, IP Address Filtering, Tampering Alarm, Access Policy, ARP Protection, RTSP Authentication, User Authentication
Network
Protocols: IPv4, IGMP, ICMP, ARP, TCP, UDP, DHCP, RTP, RTSP, RTCP, DNS, DDNS, NTP, FTP, UPnP, HTTP, HTTPS, SMTP, SSL, QoS
Compatible Integration: ONVIF (Profile S, Profile T), API
Interface
Network: 10M/100M Base-TX Ethernet
General
Power: DC 12V±25%, PoE (IEEE 802.3af)
Power consumption: Max 5.5W
Dimensions (Ø x H): Φ126 x 94mm (Ø5.0” x 3.7”)
Weight: 0.45kg (0.99lb)
Operating Conditions: -30℃ ~ 60℃ (-22°F ~ 140°F), Humidity: ≤95% RH (non-condensing)
Ingress Protection: IP67
