код товару: 701886
Camera | IPC6252SR-X22U | IPC6252SR-X22UG |
Sensor | 1/1.9', progressive scan, 2.0 megapixel, CMOS | |
Lens | 6.5 ~ 143 mm (22x optical zoom) , AFautomaticfocusing andmotorizedzoomlens | |
Angle of View (H) | 70° (wide) ~ 3.76° (tele) | |
Shutter | Auto/Manual; shutter time: 1/6 s ~ 1/100000 s | |
Minimum Illumination | Colour: 0.001Lux (F1.5, AGC ON) 0 Lux with IR | |
Iris | Auto/Manual; F1.5 ~ F3.4 | |
Day/Night | IR-cut filter with auto switch (ICR) | |
Digital noise reduction | 2D/3D DNR | |
S/N | >52dB | |
IR Range | UP to 200m (656ft) | |
·Defog | Digital Defog | |
WDR | 120dB | |
Video | ||
Video Compression | Ultra 265,H.265, H.264, MJPEG | |
H.264 code profile | Baseline profile, Main Profile, High Profile | |
Frame Rate | Main Stream:2MP (1920×1080):Max. 60 fps; Sub Stream:2MP (1920×1080):Max. 60 fps; Third Stream: D1 (720×576): Max. 60 fps | |
HLC | Supported | |
BLC | Supported | |
EIS | Supported | |
OSD | Up to 8 OSDs | |
Privacy Mask | Up to 8 areas | |
ROI | Supported | |
Motion Detection | Up to 4 areas | |
Smart | ||
Behavior Detection | Intrusion, cross line, motion detection, Auto tracking | |
Exception Detection | Audio detection | |
Intelligent Identification | Face detection | |
Statistical Analysis | People counting | |
General Function | Watermark, IP Address Filtering, Tampering Alarm, Alarm input, Alarm output, Access Policy, ARP Protection, RTSP Authentication, User Authentication | |
Audio | ||
Audio Compression | G.711 | |
Two-way audio | Supported | |
Suppression | Supported | |
Sampling Rate | 8 KHZ | |
Storage | ||
Edge Storage | Micro SD, up to 128 GB | |
Network Storage | ANR | |
Network | ||
Protocols | IPv4, IGMP, ICMP, ARP, TCP, UDP, DHCP, PPPoE, RTP, RTSP, RTCP, DNS, DDNS, NTP, FTP, UPnP, HTTP, HTTPS, SMTP, 802.1x, SNMP | |
Compatible Integration | ONVIF(Profile S, Profile G), API | |
Pan & Tilt | ||
Pan Range | 360° (endless) | |
Pan Speed | 0.1°/s ~ 240°/s | |
Preset speed: 300°/s | ||
Tilt Range | –15° ~ +90° (auto reverse) | |
Tilt Speed | 0.1° ~ 160°/s | |
Preset speed: 240°/s | ||
Number of Presets | 1024 | |
Patrol | Preset patrol, route patrol, recorded patrol | |
Home Position | Supported | |
Interface | ||
Audio I/O | Audio cable | |
Input: impedance 35 kΩ; amplitude 2 V [p-p] | ||
Output: impedance 600 Ω; amplitude 2 V [p-p] | ||
Alarm I/O | 2 / 1 | |
Serial Port | 1 RS485 | |
Network | 1 RJ45 10M/100M Base-TX Ethernet | 1 RJ45 100M Base-FX SFP+10M/100M Base-TX Ethernet |
Video Output | 1 BNC, impedance 75 Ω; amplitude 1 V [p-p] | |
General | ||
Power | 24 V AC (Default) ±25%, 24 V DC±25% | |
Power consumption: 11~47W | Power consumption: 11~47W | |
Dimensions(ØxH) | Ø227x359.4 mm (Ø8.9” x 14.2”) | |
Weight | 5.5kg (12.1lb) | |
Working Environment | –40°C ~ +70°C (-40°F ~ 158°F), Humidity:10%~ 95% RH(non-condensing) | |
Ingress Protection | IP66 | |
Reset Button | Supported |
